I just tried to put the new stick of RAM in my computer it didn’t work so I put my old ram back in and now my PC won’t post, it’s not giving me any post codes, I tried reseating the ram,I tried reseating the GPU, and I tried resetting the CPU, it still won’t work, please help...
https://linustechtips.com/topic/1202974-i-need-help/
Just now, ladiesman2179 said:
I just tried to put the new stick of RAM in my computer it didn’t work so I put my old ram back in and now my PC won’t post, it’s not giving me any post codes, I tried reseating the ram,I tried receiving the GPU, and I tried resetting the CPU, it still won’t work, please help...
Put the old stick of memory in where you took it out.
Clear cmos and see if the system posts up.
https://linustechtips.com/topic/1202974-i-need-help/#findComment-13665678
Sometimes, your system will take a while to boot up when you mess with the RAM.  If it didn't give a fault code, it's probably boot cycling a bit.  Try giving it like 5 minutes or so to boot.
If that doesn't work, then do what ShrimpBrime said, and clear the CMOS.
https://linustechtips.com/topic/1202974-i-need-help/#findComment-13666154
