So i recently build a new pc with the parts below and since building it ive had nothing but problems with memory management blue screens and when playing games game just closing down with no crash error but in the event view it comes up with event id 51 "An error was detected on device \Device\Harddisk0\DR0 during a paging operation." but the only thing i thought it could be would be a fault motherboard or the ram and m.2 all the bios is up to date as well as drivers chipset divers and fresh installed windows to see if that would help i would love to see what everyone thinks it could be.
Pc parts
CPU: Ryzen 5 3600
MOB: Gigabyte A320m-h
Ram: Corsair Dominator 16GB 3200mhz
Hard Drive: Crucial 500GB Nvme m.2
GPU:GTX: Zotac GTX 1660 Super
PSU: seasonic GM500 gold 80+
https://linustechtips.com/topic/1199659-new-pc-problems/
That sounds like a hard disk problem, based on the error message.  When placed into the google search the message returns this:  https://www.wintips.org/how-to-fix-disk-event-51-an-error-detected-on-device-during-paging-operation/
As for your RAM, you may have a problem there too because the MOBO manufacture page says it does not support 3200 speed memory.
https://linustechtips.com/topic/1199659-new-pc-problems/#findComment-13641208
37 minutes ago, reece90100 said:
yeah i know its a hard disk problem but dont know if there is a main problem with the motherboard thats causing the 2 problems this is where is got the motherboard and it says it dose
First thing i would do is to update the MBO BIOS, install the latest AMD A320 chipset drivers, insall all windows updates, after that you can download the hard disk sentinel software to chech heath of SSD drive, as for memory, memory can be tested with memtest86+ or the fast way, if you have two sticks, try using only one.
https://linustechtips.com/topic/1199659-new-pc-problems/#findComment-13641326
