Budget (including currency): Around 100-200 USD
Country: Unite states
Games, programs or workloads that it will be used for: I need a GPU that can perform well on 1080 high on most games
All I need are GPU recommendations to pair with the new R3 3300X
Thanks
AMD Ryzen 5 3600 @3.8 Ghz. -  Gigabyte B450 Aorus M - Asus TUF Gaming GTX 1660 SUPER 06G - GSKill Ripjaws V 16gb 2x8gb DDR4 @3200 Mhz. - Inland Premium 512gb NVMe SSD - Rose will RD 450 Watt 80+ - DIYPC s2-BK-RGB ATX Mid-tower case.
https://linustechtips.com/topic/1196896-i-need-help-picking-a-gpu/
1 minute ago, _DeXTeR_ said:
One thing is you didnt told us do you plan to buy used or new GPU, but OK so this are my suggestions
if you have powerfull power supply I would go for rx 590 its around 160-190$ on Newegg
https://www.newegg.com/sapphire-radeon-rx-590-100415p8gl/p/N82E16814202333?&quicklink=true
If you do not have that great PSU you can go with rx 580 8gb
https://www.newegg.com/msi-radeon-rx-580-rx-580-8gt-oc/p/N82E16814137479
And if you want to buy used Graphic card you should definitly go for GTX 1070 you will be happy with price to performance.
Thank you so much, I have not yet decided whether or not I will buy used, but thanks for the suggestions.
