Context: Built this rig last july and it saw very minimal use. In feb. it was having problems where my browser tabs would crash or the entire machine would crash. I used one of the default memory diagnostic programs that just gives a broad output of 'Hardware problems detected Contact manufacturer.’ So i figured there was something wrong and i sent it to corsair using the limited lifetime warrantee and got my replacement. the same thing was happening so i changed the freq to auto which set it at around 2133 and it was working fine. i played space engineers for an extended time yesterday and now i just get a white dram ezdebug light when i try to power it on. No amount of reseating has helped and i even tried jumping jbat1 to reset the cmos and nothing. really dont understand how overnight it just decides to stop working.
specs
Ryzen 5 2600
corsair vengeance lpx 3000mhz 16gb
b450m pro-m2 mobo
xfx rx580
500w evga 80 plus psu
https://linustechtips.com/topic/1196661-white-ezdebug-dram-light-no-post/
3 hours ago, bebejapes said:
try resetting the bios to factory and then check if you have an upgraded bios.
once your bios is up to date run mem test to check your cpu and ram sticks for any problemss
pulled the cmos battery, waited. tested again and nothing. cant get into the bios without working ram and i dont have any spares though these are brand new
