So its my first build right, and i notice that my ryzen 5 3600 is idling at 60-50, thats not too good i say to myslef, and check on the stock cooler, turns out the fan mount is broken on one side so 2/ of the 4 mounts are in, and the screws dont want to screw in anymore. i need a cpu cooler im thinking of getting the DEEPCOOL GAMMAXX L120T since it comes with its own fan mount/bracket. Could you guys give me tips since im new to all of this?
https://linustechtips.com/topic/1196606-help-fan-mount-broken/
Just now, Darpyface said:
You can probably get a new backplate off ebay for $5
I tried looking for it but its all cheap stuff, and i looked at the comments and they say its like a cm too short and stuff
https://www.amazon.ca/PartsCollection-Retention-Bracket-Cooling-Mounting/dp/B07C2BXDQM
https://linustechtips.com/topic/1196606-help-fan-mount-broken/#findComment-13617795
15 minutes ago, Darpyface said:
YOU ARE A LIFE SAVER, THANK YOU
https://linustechtips.com/topic/1196606-help-fan-mount-broken/#findComment-13617834
