Recently discovered that I have this black pixel with a weird line of white pixels around it. Don't know exactly when it happened but it happened while my PC was on (Pretty sure, unless I haven't noticed when I turned it on which is unlikely).
When I open quite a dark background/open an image popup box, the pixel turns white. I can also screenshot the pixel? Didn't think that was possible as I thought dead pixels were a problem with my display, not something actually there, which makes me think it's something else. What is this, can it get worse, is there any way I can fix it?
image.png.209a6ca605371cee9c0d86078ef9f0e9.pngimage.png.4216a7fdf8ed2aa0f378680e1fb62c82.png
https://linustechtips.com/topic/1194638-dead-pixel-or-not/
If you can screenshot that... I dunno man. Theres defiantly some smart people that can help you out but I predict that this is just minor, or it's something worse than it seems.
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
https://linustechtips.com/topic/1194638-dead-pixel-or-not/#findComment-13602964
Dead Pixels dont appear on a Screenshot. Check your Cable and try to reinstall the driver. Sometimes weird issues can have a very simple solution.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1194638-dead-pixel-or-not/#findComment-13603002
