so here is what i got i have asus m4a89gtd-pro usb3 mother board yes i no its old but it dose what i want . when I built this unite i had 8gb of ram so recently i decided to up the ram to 16gb ,yes the board supports it , when i put the new ram in windows,cpuz and speccy sees it all but when i go in to bios it only sees half . tried clearing the cmos both by battery and the jumper but still the same. So i decided to put the old ram back in and even that is now showing in the bios as only half. the bios are as updated as it can go . Was thinking of just reflashing the bios to see what it would do . And yes i have reseated the ram and tried each stick one by one and they will show as supposed to . I just dont understand why the other programs see the ram but windows says that the 4gb are in reserve and bios dont see it at all . Any help would be appreciated     thanks
https://linustechtips.com/topic/1193350-help-with-ram-issue/
  • 3 weeks later...
sorry so long to reply but you where right some how the cpu got a few pins bent so i upgraded the cpu till i can look at the old one closer . but now i have a different problem after i replaced the cpu and i up graded the ram when i start windows it hangs on the loading screen ,i looked it up and every one show a fix but the talk about when you get the windows logo with the spinning dots. What mine is doing is you get the logo but no dots so i restart the pc and it loads as normal . this is windows 10 pro . I didnt have this till i did the upgrade  should i do the fix that they all say or try something different??  any ideas ????   and thanks again
https://linustechtips.com/topic/1193350-help-with-ram-issue/#findComment-13652264
