So, get ready to hate, but I tried overclocking a cpu that couldnt be over locked by upping the core voltage, the pc whenever I turn it on now shuts off and reload itself instantly which occured after I tried overclocking before I realised I couldnt. Any idea how I can fix this? Very inexperienced...
https://linustechtips.com/topic/1191462-tried-overclocking-cpu/
Socket 478 responded well to lower temps and good voltage increase. Which DDR 400 sticks do you have?
https://linustechtips.com/topic/1191462-tried-overclocking-cpu/#findComment-13580053
56 minutes ago, Swallowtail said:
Try resetting your Bios by removing the round battery on your motherboard, wait for 5 minutes and put it back again. That should work
Thanks for the response, got any example images of what this should look like?
Edit: that was a stupid question, i'll try and let you know, thanks!
https://linustechtips.com/topic/1191462-tried-overclocking-cpu/#findComment-13580211
