So .. after finally building my first pc I have been experiencing some problems... After one week of use I have been experiencing some random freezes which sometimes make the whole system restart or others just freeze and not being able to do anything rather than watching a black screen .. I have not even  had a blue screen pop up after it before the restart but yet the problem is still there ... All the hardware seems to be working just fine
Drivers are up to date and downloaded from my motherboard's site.
Pc specs
- CPU : AMD 3 3200G
- Motherboard: Asrock AB350 r.2
- RAM : 8GB (2X4 *in the correct slots for dual channel )*PATRIOT viper 4
-PSU : CROSAIR VS550 White
If anybody can help it would be much appreciated
Thanks in advance
https://linustechtips.com/topic/1190752-i-need-some-help/
Don't use graphics drivers from your motherboard manufacturer. Run Display Driver Uninstaller from https://www.guru3d.com/files-details/display-driver-uninstaller-download.html and grab current display drivers from https://www.amd.com/en/support/apu/amd-ryzen-processors/amd-ryzen-3-desktop-processors-radeon-vega-graphics/amd-ryzen-3-1.
Make sure to quote me or use @PorkishPig to notify me that you replied!
Desktop
CPU - Ryzen 9 3900X | Cooler - Noctua NH-D15 | Motherboard - ASUS TUF X570-PLUS RAM - Corsair Vengeance LPX DDR4-3200 32GB Case - Meshify C
GPU - RTX 3080 FE PSU - Straight Power 11 850W Platinum Storage - 980 PRO 1TB, 960 EVO 500GB, S31 1TB, MX500 500GB | OS - Windows 11 Pro
Homelab
CPU - Core i5-11400 | Cooler - Noctua NH-U12S | Motherboard - ASRock Z590M-ITX RAM - G.Skill Ripjaws V DDR4-3600 32GB (2x16)  | Case - Node 304
PSU - EVGA B3 650W | Storage - 860 EVO 256GB, Sabrent Rocket 4.0 1TB, WD Red 4TB (x6 in RAIDZ1 w/ LSI 9207-8i) | OS - TrueNAS Scale (Debian)
https://linustechtips.com/topic/1190752-i-need-some-help/#findComment-13574424
That seemed to fix the freezes ... Hope I don't get it again thanks a lot for the replies
https://linustechtips.com/topic/1190752-i-need-some-help/#findComment-13576775
