Hey. I just built a new Ryzen 3700x system and I tried installing the Ryzen Master utility, however when I try to launch it after installation, it says "Ryzen Master failed to initialize. Kindly reinstall the program." I reinstalled it a few times now but still no result. Does anyone know what's causing this problem? Thank you!
https://linustechtips.com/topic/1190503-ryzen-master-not-working/
Just my opinion but I would stay away from those vendor software solutions and use more stable alternatives they seem to always be problematic what exactly do you want to do with it? I would not overclock with it use the bios its more stable
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
I don't plan doing any crazy overclocking, just going to turn on precision boost
11 minutes ago, Premilix said:
Do I uninstall the current drivers straight from the device manager?
Go to your boards web page and download the current driver then you can update from the device manager
Well, I tried a lot of things and now it works. I don't really know what caused it but maybe Me installing a 2009 Microsoft driver from the device manager on my Ryzen 7 3700x. I also installed the chipset driver from my mobo's website but it still says 2009 on the CPU (idk maybe the chipset and CPU have different drivers i'm a bit stupid).
those are your cores and threads
