17 minutes ago, bacithecat said:
my monitor doesnt have a vesa mount. is there an adapter i can buy for it?
Yes. You can look at https://gladiatorjoe.com/ Its where I bought mine for my monitor. They didnt have the template for my monitor so they had me take pictures and send it to them and they made one for my monitor since Acer changes styles on there stuff every year or 2.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1187737-vesa-mount-adapter/#findComment-13552882
If you have a monitor that is nothing special and you dont mind modding adding vesa mounting is easy.
All you need is to take the back panel off, drill 4 holes, and use bolts and nuts to secure it to the mount.
Ive got an old old 32" tv in the shed i had to do that to and have had no issues in over two years.
https://linustechtips.com/topic/1187737-vesa-mount-adapter/#findComment-13553133
