Hey, I was trying to build a NAS/VM box between two old machines I found and I was wondering witch one to use with 6 HDD and 2 SDD totaling 13 TBs:
Core i7-6700k
ASUS Maximus viii Gene
Ripjaws DDR4 32 Gig 2133
or
Zeon E3-1275
Asrock Z77 Extreme4
Dell DDR3 32 Gig 1600
I was thinking about adding a GPU to the i7 machine for a HTPC/gaming machine but I'm not sure if it would be better for the NAS. Also I was thinking of using Freenas because I am familiar with it but I was also thinking about using UNRAID.
________________________________________________________________________________
Processor | AMD Ryzen® 5 3600X CPU @ 4.60GHz | Memory | 16GB RAM 3200 Mhz | Video Card | NVIDIA GeForce 1660 Ti | Hard Drive | 1 TB 4x4 M.2 SSD | Motherboard | ASRock X570 Steel Legend | OS | Windows 10 for Workstations 64x
https://linustechtips.com/topic/1185973-nas-config-help/
Core i7-6700k
or
Zeon E3-1275
Asrock Z77 Extreme4
I built my unRAID server based on my pre-built I7 6700 and it is rock solid its currently at 28TB with 10-15 dockers running no vms and is at 15-20% utilization so plenty still left in the tank if your planning an HTPC based around plex look into a quadro p2000 for heavy transcoding if thats your thing see my sig below
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
https://linustechtips.com/topic/1185973-nas-config-help/#findComment-13539783
