Hi
I am upgrading this PC from Windows XP to Win 10 Pro for a friend, now Im running in to problems after the upgrade. I can not get any Graphics driver nor sound driver out of it, stating its last graphic update on 2009 in Device Manager. I have done Windows Update already. But Please see attached Screenshot to help me advise or fix the problem. See info on Mother and CPU on attachment. Note it has no GPU installed just normal VGA output on the I/O.
I can not even run a Simple NFS Underground 2 game, it runs on almost 8 FPS
or I should tell this Guy to buy a Graphics Card for his old PC so it can run normally.
I will appreciate your quick response on this matter
Thank You
I'm from South Africa, KZN
https://linustechtips.com/topic/1185784-sa-pc-fix-n-tips/
