I used to play a lot of War Thunder but then it started constantly crashing on me. The games just freezes completely and I have to hold the power button to reset it. As I never had a problem with Battlefield 1 I assumed it was a problem with WT and have been too busy with work to investigate further. Due to the lock-down I downloaded Call of Duty: Modern Warfare and Far Cry 5, now I get the same problem with both of them. I have checked with MSI afterburner and temps are <60 degrees and GPU/CPU are not maxing out.
GPU drivers are up to date and McAfee is not picking anything up. MemTest86 ran without any issue GPU-Z render test ran with no problems
OCCT: occt ran for 1:30h with 0 errors OCCT:Linpack ran without errors 3h OCCT: Memtest also ran for over 1h without errors
OCCT: 3D ran for 530seconds then froze with 0 error count. OCCT: Power also froze the system within 5mins just like the 3d test. As with gaming the system froze and I had to hold the power to reboot. I have run the above tests a number of time with the same result although I did get the 3D test to run for over an hour once.
Very occasionally it gave an bsod but I would say 99% of the time it was just a freeze without (cannot remember the error codes). Sometimes when I restart (holding power button) it will go into a cycle of powering on and off (prior to any beep codes). When this happens I generally have to unplug it for a few mins and then start it again.
One thing I am sure it is not is the power supply. This was my initial suspicion when WT had issues and I changed from beQuiet Straight Power to the Seasonic one I have now.
This has become a bigger issue yesterday when the TV decided to stop working and I have to wait a full week to get a new one delivered.
INTEL Core i3-8100
HyperX Fury DDR4 2666 2x8GB
ASUS B360M-A
KFA2 GTX 1060 OC (6GB)
Seasonic Focus Gold (450W)
ADATA XPG SX8200 240 GB SSD / SEAGATE Barracuda 2 TB HDD
https://linustechtips.com/topic/1181079-occt-power-freezing/
