I'm planning to build a PC using an AMD Ryzen 3700x with one of the RTX 2060 series graphic cards. The game I most excited to probably play using ray tracing is Minecraft. Now my question is regarding the video that came out yesterday. If I went for the Super 2060 instead of KO would the FPS be higher and would the shadow processing lag disappear if I kept the same setting as the tests from the video? I care more about the shadow processing lag to disappear but if the Super doesn't get rid of it, would it be better to save up for a 2070 Super instead?
That's how its implementation works, a faster card can reduce it (I think it's fps affected) but it wont remove it since even the 2080ti is not fast enough to hide the shadow lag
Desktop benching:
So at this point it is better to just wait another year for improvements in the GPU market? I wasn't planning to build my PC till the end of this year/beginning of next year. Thanks for the response though
This alone is why you should seek advice when you're ready to build, things change too quickly for half year old advice to be any useful
Desktop benching:
