I am planning the following build
Processor: ryzen 5 3500
Motherboard: gigabyte b450m ds3h
GPU: asus Radeon Rx 580 dual oc 4gb
Storage : 1tb Seagate barracuda at 7200rpm
Ram : adata 8gb at 3000mhz
I am still undecided on the case
I plan to use a cooler master mwe 550
Psu .
Will it work ??
If not please recommend something similarly priced cause i am on a tight budget
Please help!!!?
Any help is appreciated and thanks in advance if you are taking the time to read this and help me
Love from India
https://linustechtips.com/topic/1177859-will-the-psu-work/
Psu .
Will it work ??
Please help!!!?
Love from India
What version of the mwe 550? White, bronze, gold?
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480336
Functional? Yes. Can you do better? Yes. Pretty sure the CX450 is affordable in India.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480359
https://mdcomputers.in/corsair-cv450-80-plus-bronze-cp-9020209-uk.html
Would this be any better??
And will it be able to supply enough power to the power hungry rx 580??
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480385
3 minutes ago, Tanaim said:
Cx 450 costs the same as mwe 550
But will 450 watts be enough for the build
Plenty. I've run a GTX 1080 and Ryzen 5 3600 off of a CX450.
I can't recommend the Corsair CV. The only good one is the 650 watt because it's made different.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480393
https://mdcomputers.in/corsair-cx450-80-plus-bronze-cp-9020120-uk.html?search=Cx 450
Will this be good enough
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480403
Just now, Tanaim said:
That's the exact power supply I recommended
So yes
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480406
6 minutes ago, jaslion said:
This is the absolute cheapest unit I can recommend
https://mdcomputers.in/corsair-cx550-550-watt-80-plus-bronze-cp-9020121-uk.html
As I am on a tight budget should I switch from a b450m to a  a320m pro max
This would help me stay in my budget
And will I experience any performence issues with this mobo
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480427
5 minutes ago, Tanaim said:
Will I have any problem in wattage or heating
Wattage, no.
Heating, do you mean if the PSU will get too hot?
I do not recommend A320 motherboards, they are very limited. Here are some motherboards that you might be able to afford that are guaranteed to work with 3rd gen ryzen:
ASRock B450M/AC
Gigabyte B450M S2H
MSI B450M Pro-VDH MAX
These are all decent motherboards and are often quite cheap.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480437
2 minutes ago, Fasauceome said:
Wattage, no.
ASRock B450M/AC
Gigabyte B450M S2H
B450m pro max and cx 450
Is what I should go with??
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480449
Specifically the Pro-VDH, not to be confused with the B450M-A Pro, also not to be confused with the B450-A Pro (MSI has made some very confusing names, lots of "pro" motherboards). This one
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480464
Let me link it to you https://mdcomputers.in/msi-b450m-pro-m2-max.html?search=B450 m
Finally are sure that my system won't blow up if I use cx450?
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480483
9 minutes ago, Tanaim said:
That one's pretty bad
RX 580 draws about 200 watts. Ryzen 5 3500 draws less than 100 watts. You have a ton of power left over.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1177859-will-the-psu-work/#findComment-13480529
