Help! CoD WWII stuttering!
Go to solution Solved by mbntr,
the problem is the lack of ram, you seem to have 8gb, COD is a memory heavy game
Please read
I've noticed newer CoD games suffer from this issue, starting with CoD Black Ops III. I want to get to the bottom of this. I've applied fixes such as setting memory to 0.75 and vram overhead to 0.43 but the game still stutters.
The game runs very smoothly at 60 fps constant at any settings but when stutters occur it ruins the entire experience. The usual pattern: 60 fps --> stutter --> 60 fps --> stutter --> repeat.
I've disabled all the unnecessary startup programs, reset virtual memory, deleted value for useplatformclock, even using the Intelligent Standby list cleaner.
Nothing seems to fix this game.
No other games do this except CoD games from BO3 onwards.
The "System Process" seems to be using the disk alongside CoD WW2 and I'm not sure how I can fix it.
Please help, any experts out there.
https://linustechtips.com/topic/1175781-help-cod-wwii-stuttering/
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
Agh. Consoles have the upper hand again with their optimisations. How do they survive with 8 GB RAM and 5400 RPM HDD in this day and age, but still run games as they should? Optimisation I guess.
this is a really good question... anyways I would suggest adding an 8gb dimm, they are pretty cheap nowadays
Laptop:
Photography:
Cameras:
35mm Film:
Lenses:
Meike MK-50mm ƒ/1.7
