Please, I need help finding a case for my watercooling build, has to meet the following requirements:
- must fit a 360 rad (45-50mm) + standard fans in the top (or side). It will be used as an exhaust.
- must fit a 240 rad (45-50mm) + standard fans in the front / bottom,
- must fit a 30cm long GPU and not come in conflict with the front rad.
- would be really nice if I could fit a rad between above mentioned long GPU and front rad.
The new Fractal Design 7 XL fits these requirements (and I love it) but it is kind of expensive, so I need to find one that meets the above requirements but also is a bit cheaper than the Fractal 7 XL.
Thanks!
https://linustechtips.com/topic/1174942-watercooling-case/
Check the Fractal Design Define R6.
It fits your requirements and is cheap than the 7.
  • CPU
    Intel i7-8700k
  • Motherboard
    ASUS ROG Maximus X Code
  • RAM
    32GB Corsair Vengeance LPX DDR4 3000MHz
  • GPU
    2x ASUS Strix 1080Ti OC
  • Case
    Fractal Design Define R6 Gunmetal TG
  • Storage
    250GB Samsung 960 EVO
    2x 500GB Samsung 850 EVO
    1TB Samsung 860 EVO
    2x 256 GB Samsung NVME SSD
  • PSU
    Corsair HX1000i
  • Display(s)
    Alienware AW3418DW 34" 21:9 1440p
  • Cooling
    Custom watercooling loop with 2x 360 Rad + 1x 560 Rad
https://linustechtips.com/topic/1174942-watercooling-case/#findComment-13457634
