I have a HP Omen 17-an053nr with i7 7700hq and gtx 1070. My cpu temp gets to 97 Celsius and my gpu gets high as well "dont remember the exact temp". I do a lot of gaming and folding@home when not gaming or using. What can I do besides applying better thermal paste? I also heard of undervolting, but I'm unsure what's the lowest I can set can set it at without effecting my gaming or folding@home. Please  help thank you.
https://linustechtips.com/topic/1171815-cpu-and-gpu-temperature-too-high/
Have you tried cleaning your laptop?
PC:
CPU: AMD Ryzen 5 2600
GPU: MSI GTX 1070 8GB
Storage: WD Blue 1TB HDD, WD Blue 500GB SSD
CPU Cooler: NZXT Kraken m22 AIO Cooler
RAM: 16GB 2666MHz HyperX Fury
Motherboard: GIGABYTE B450M DS3H
Case: Phanteks P400
PSU: EVGA 450BV
I googled some reviews and it does sound a toasty laptop in general.
Quote
During our stress test, CPU core temperatures were around 90 °C (maximum specified core temperature: 100 °C). The CPU throttled from 3.8 to 3.1 GHz. The GPU reached around 70 °C and throttled as well (around 1.2 GHz).
If you've had it a while then as you say, dust, thermal paste, undervolting, all possible options to look at.
Bear in mind that something like F@H is pretty much a stress test, its going to push your hardware harder than pretty much any other workload so is particularly prone to hitting high temps on laptops.
Thanks for the information.
1 hour ago, Crazyjoe909 said:
Would you happen to know what's the lowest voltage on my cpu without effecting my gaming or F@H?
That's the thing with under-volting, it varies from CPU to CPU, some might not under-volt at all.
I've never messed with it myself as its so time consuming reducing the voltage a little, test for stability, reduce it a bit more, since and repeat until its no longer stable then increase it back up to the lowest stable voltage.
