While this is very vague, I will try to help anyway. I think your hard drive might be dying.
Turn on your PC and open "activity monitor" (it's a part of Windows). Then open the disk tab. On the right, if should show some graphs. Can you send a screenshot of the hard disk queue when it is working fine and then another as close to when it crashes as possible.
This has helped me figure out crashes before in the past as a high disk queue next to crash shows the HDD was overwhelmed somehow.
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13418838
25 minutes ago, Budget gamerXD said:
My PC randomly freezes while somebody is using it.
I have windows 10 on hdd
Could it be the hdd or maybe graphics card
Open task manager and observe the usage of your components. Share your computer specifications so that we can locate the potential performance issues.
Mostly, the hard drive usage must be 100%, i.e, some processes must be accessing your hard drive all the time and because of that, other essential windows process could not access it, leading to a system freeze.
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13418869
If the hard drive was "dying" or "failing", the system would crash to a blue screen. Since that is not happening, I think it is more of a background process issue. What you think?
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13418876
No, it wouldn't.
I personally think both of you are wrong. If his drive was dying, his PC would be unusably slow, not freezing or crashing. It would take twenty minutes to open Chrome but he could at least move the mouse or use already opened programs while he's waiting.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13419006
49 minutes ago, kelvinhall05 said:
No, it wouldn't.
My HDD makes like buzzing/scratching noice on 100% usage
If this helps please help XD
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13419098
6 hours ago, kelvinhall05 said:
No, it wouldn't.
I've myself experienced a failing hard drive. The common outcomes were freezes and system crashes. But since this guy's system does not crash, doesn't it seriously looks like a "always 100% disk usage" or  "always 100% CPU usage" scenario?
Pls give us some more info like screen shot of task manager??
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13420269
100% on boot and first time loads
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13420487
We could help you if you would kindly tell us your specs and approximate age of your system ^.^
My system is 10yr old but that is what you get as a 13yr old.
Specs are i5 660
hd 7730 2gb gddr5
I think HDD is wd blue
Mobo hp 304bh
6gb ram, 3 sticks, one stick died, it was 8gb
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13420499
That is expected as windows starts all necessary services.
Specs are i5 660
hd 7730 2gb gddr5
Mobo hp 304bh
Your spec are pretty decent and this should not be causing any freezes I suppose. But since your system is 10yr old, is it cleaned?
I mean if your PSU or CPU fans are clogged, you might suffer from such situations. It may also be your HDD since its 10 year old, but HDD last quite long (As per my experience). Have you cleaned your system thoroughly?
https://linustechtips.com/topic/1170266-pc-randomly-freezing/#findComment-13434057
