I have asus ac 58 u, in the spec page it says,
MIMO technology
2.4 GHz 2 x 2
5 GHz 2 x 2
now i have one pc and a phone primarily, the 5ghz i use only for pc and 2.4 ghz i use for phone,
so my question is since this router supports mu mimo, is it transmitting to pc and phone simultaneously, or like the turn by turn way, for pc then phone then again pc then phone?
also is every dual band router mu mimo if one device is connected to 5ghz other to the 2.4 ghz
https://linustechtips.com/topic/1169545-asus-ac58u-help-please/
Wireless is generally half-duplex. You either receive or transmit at once, not at the same time. MU-MIMO allows transmitting and receiving at the same time, for example router sends signals to one device, at the same time receives signals from another device. MU-MIMO will not improve single device connection in any way.
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/1169545-asus-ac58u-help-please/#findComment-13412399
