SO i have a old projecter and im trying to get it running for my dad, i have it convinced it has a lamp and using my tac light for my rifle i was able to confirm all is running normal as it should, now i am Looking to make a new lightsource for it. i have found a 30watt LED and Driver, both of which will fit internally in the positions that the old ballast and lamp sat. but i need a heatsink. I have uploaded pictures with the dimensions,
2 inch x 2 inch x 2.5 inch.
Rough Translation
50mm x 50mm x 60mm
now i have found some northbridge and ram heatsinks that would fit but at only 10mm tall it seems to me like it would get overheated fast. it will have air flowing through it provided by the fans already in the projector, any heat sinks that you guys have seen that would fit?
Thanks Guys, Dragon "Fullmetal" 1212
post-60189-0-11194900-1392605840_thumb.j
post-60189-0-14897200-1392605858_thumb.j
post-60189-0-57379700-1392605874_thumb.j
Thanks Guys! Fullmetal
You must NEVER go over 20% fan speed. ~ "Why's that?"~ Why do airport personnel wear hearing protection?
https://linustechtips.com/topic/116841-led-cooling-tight-spaces/
a aio watercooler maybe? a small heasink might not be enough
don t forget leds require lots of cooling compared to the power they use since they re isolants so the temp inside could melt the electronics while the outside would reach only 40c. (think cpu with extremely bad tim under the heatspreader)
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
https://linustechtips.com/topic/116841-led-cooling-tight-spaces/#findComment-1561501
Yea that wouldn;t work for this unit then. my tac flashlight, a Hugsby P2 produces a watchable, albeit dark image, but we tried my cars HID headlamp in the projectors factory housing and the light is so thrown around it barely produces a image at the front of the projector.
Hugsby P2 Tac Light - 190 lumens
H1 HID Kit - Approx 3200 Lumens?
in the housing the light from the HID it directs forward is enough to light up the other side of a field out here, but the second its in the projector I can look in the lens backward and then i can see it. my tac light you'd damage your eyes doing the same.,.. what the ?
https://linustechtips.com/topic/116841-led-cooling-tight-spaces/#findComment-1563751
I would do this :
Buy this http://www.ebay.com/itm/100W-Cree-XM-L2-White-LED-100-Watt-12V-24V-Dimmable-Waterproof-Led-Driver-Kit-/360753181923?pt=US_Lighting_Parts_and_Accessories&var=&hash=item53fe90b4e3
Mount a laptop heatsink and heatpipe to it , solder extra copper or use a laptop fan to cool it.
Main Rig : i7 5960X - 16GB DDR4 LPX 2400mhz - Asus Rampage V - 980GTX Ti - AX1200i - 650D - H110 - 1TB 840 EVO SSD - 30 inch HP 1600p IPS + 2xHP 20 inch 1600x1200 PLP setup! - Oculus DK2 - Logitech G502 - Corsair K70 RGB - Fanatec GT3 Wheel
i7 3930K - 16GB DDR3 2133mhz - Asus Rampage IV - 2 x 680GTX - AX850 - 550D - H100i - 256GB 830 Pro SSD - 2713HM 1440p IPS - G5 -
i5 3570K - MSI SLI Z87 motherboard - 4GB Corsair 1600mhz - Adaptec 31205 - Dell Perc 5/i - Intel Quad PT1000 Gigabit Network Card - Loads of 4TB RED's - +-70tb total storrage - HX850watts - Ri-Vier 24bay 4 U case
https://linustechtips.com/topic/116841-led-cooling-tight-spaces/#findComment-1568110
