I am fairly new to pc building, I am using a ryzen 5 3600 with the stock cooler wraith stealth. When the pc is idling with nothing open, temperatures cpu idle temperatures fluctuates between 37C and 55C, and sometimes it even jumps straight from 38C to like 54C, I just wanted to know if this is normal.
https://linustechtips.com/topic/1167363-cpu-idle-temp-fluctuating/
Does this happen while under load ?
