since i got my new PC I have got some problems. Everytime I play GTA 5 after about 20-30 minutes, the fans of my PC, especially GPU fans are maxed out. My screens turn black and get no signal.
I have read through other topics to this where the gpu was overheating and they had to replace the thermal paste.
But on gta 5 my GPU reaches 60° Celsius max. On other games, like ARK my GPU is on 85° and the fans are nearly maxed so i dont think the heath is the problem. And I also only happens in gta 5. When this happens I have to turn off the power supply, otherwise the pc wont do anythiing.
Then if I turn on the power supply again, my PC starts without me pressing the start button. after this gta 5 workes without any problems, UNTIL I restart the PC again.
The other Games I play WITHOUT problems:
GTA 4
ARK
Assasins Creed Syndicate
The Witcher 3 on three monitors = 5750 x 1080
Minecraft
Red dead redemption 2
Fortnite
I play all games on maxed settings on 1920 x 1080 or 5760 x 1080
My PC specs:
CPU: i7 9700k
GPU: RTX 2080 Super Zotac
CPU-Fan: Be Quiet Dark Rock 4
Mainboard: MSI Z390-A Pro
RAM: 3000MHZ 32GB G-Skill
650 Watt power supply
Here are test results from Userbenchmark: https://www.userbenchmark.com/UserRun/25493068
https://linustechtips.com/topic/1164932-screen-black-fans-max/
GTA 4
ARK
Minecraft
Fortnite
My PC specs:
CPU: i7 9700k
what is your psu model and do you have the latest bios and do you have mce on and what is your voltage on the cpu ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1164932-screen-black-fans-max/#findComment-13373566
