Hi, my pc keeps crash while playing The Division 2 every 2-3 hrs constantly. all drivers are up to date, I've run windows memory test and memtest86 for 4hrs and found no problem, i have no idea whats going on, need help
PFN_LIST_CORRUPT
MEMORY_MANAGEMENT CRASH
SYSTEM THREAD EXCEPTION NOT HANDLED
STORE DATA STRUCTURE CORRUPTION
ATTEMPTED WRITE TO READONLY MEMORY
my system is windows 10 64bit, i built this desktop in nov 2017
ryzen 5 1600 3.2ghz (stock), stock cooler.
evga gtx 1080
asrock x370 motherboard
16gb corsair vengeance lpx 3000 mhz,
power supply seasonic focus plus gold 650w
1st dump files https://1drv.ms/u/s!Au0NUe_ECQkDjQtBGKz6tyNmGjeS?e=nD7ftL
after i tried fixing the bluetooth diver from this first dump files i crash again after an hour and got ATTEMPTED WRITE TO READONLY MEMORY
2nd dump files https://1drv.ms/u/s!Au0NUe_ECQkDjQxzZ6sWGdyiOgIx?e=dWZ6Z1
thanks!
Edited by NoobMeister
https://linustechtips.com/topic/1164440-pc-bsod-need-help/
It seems higly unlikely to me that CPU temperatures would affect memory temperatures so much they overheat. I am not saying it's impossible.
1 hour ago, NoobMeister said:
PFN_LIST_CORRUPT
Now this generally indicates a driver issue. I would invite you to find and share the crashdump (or analyse it yourself) to see if any indications are giving as to the driver(s) that may be causing this. Spoiler alert: Chances are it's not going to be able to tell you and call it unidentified.
You should give the driver identifier a shot and see what happens link.
Also, be sure that nothing is overclocked because that might be causing some instabilities and your easiest fix instead of looking for it in wonky drivers. (I am not talking about pre-loaded XMP profiles, yes technically these are overclocks but shouldn't cause these issues. You could allways try this when nothing else helps).
Also try a memtest
See what these test come up with.
No personal experience here but this post indicates that these errors are likely caused by the same faulthy drivers.
The gist of it: I think you have instability thanks to overclocking or some of your drivers are not working as they should.
Edited by FrowningHippo
XMP profile information. Deleted Memtest info since you tried that already.
https://linustechtips.com/topic/1164440-pc-bsod-need-help/#findComment-13369787
Also try a memtest
i reverted my cpu back to stock 3.2ghz with 1.23 volts, i've included my crash dump in the original post, it crashed again after couple minutes of playing while in stock ghz, this time i got ATTEMPTED WRITE TO READONLY MEMORY
https://linustechtips.com/topic/1164440-pc-bsod-need-help/#findComment-13369927
