I'm buying a laptop soon and I'm wondering weather it is worth it to get a Seagate 5400 rpm 500 gb with 64 mgb cache SSHD or put in 20-30 dollars more for a Toshiba SSHD that has 8 gb of cache instead of a measly 64 megs. Thoughts? If your wondering, I want an sshd so I can have the size of a hard drive but also have fast boot times and quick program load times without having to pay for the equivalent sized SSD.
Laptop - Lenovo Y50   Keyboard - Corsair K95 RGB Cherry MX Brown   Mouse - Logitech G502 Proteus Core   Mousepad - Razer Firefly
Please read the LTT Code of Conduct before submitting a post
https://linustechtips.com/topic/116393-quick-hard-drive-question/
Are you going to be frequently using programs with more than 64 mb of space? If not then the 8gb wont matter to you. I would just go with which ever is cheaper, you won't be able to tell the difference between the two unless you are launching large files frequently.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
