Hello all,
I have just recently bought a Ryzen 5 3600 with a b450 tomahawk max. I am currently running at stock speeds with the stock cooler on it. In idle the temperature is just below 50c. If I run prime95 the temps will reach 95c (95 max is the max setting) in 8-10 mins. I am also running a r9 200 Series graphics card which will drop to 1/2 of the clock speed for a split second every 20-30 second under full load using fur mark. Is this normal behavior?
Thank you,
Ik I should invest into a new graphics card, broke university student here.
-Henry
https://linustechtips.com/topic/1163176-ryzen-5-3600-temps/
You should invest in a decent cpu cooler.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1163176-ryzen-5-3600-temps/#findComment-13358368
The stock cooler would be enough.. You might have messed up the thermal paste.. cuz I also had similar problems with my stock cooler on ryzen 3.. I re-applied the thermal paste and it worked just fine ( 80-90C at max load) and that too an APU!
https://linustechtips.com/topic/1163176-ryzen-5-3600-temps/#findComment-13358734
