When I plug in my ethernet cable, there is a orange flashing light, and the connection in the game i play isn't as good as it has been in the past. I tried searching this up but not much help is given. The orange flashing light on the my motherboard near the ethernet port. I am using windows 10
https://linustechtips.com/topic/1162526-flashing-ethernet-light/
The orange light is a signal light, it's supposed to be flashing.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
Just now, Rygoalo8 said:
I don't know there looks to be 2 lights where the cable is plugged in and one of them is a constant green whilst the other a flashing orange.
Yes, both of those are normal.
SPECS:
