So i added a new drive to my computer (E:) I booted up my pc and my 512gb NVMe drive is now a system reserved partition. How do i fix it and get my data back like it was before i added the new disk.
(C:) 250gb sata
(D:) 512gb NVMe (before it got changed to system reserved)
(E:) 250gb sata (New added disk)
(G:) 512gb external ssd
https://linustechtips.com/topic/1159732-system-reserved-partition/
Go into disk management, change the drive letters.   remove  the letter from the "system reserved" if you want to hide that partition.
Slayerking92
<Type something witty here>
<Link to some pcpartpicker fantasy build and claim as my own>
when it happened? When you added new drive, or when you added new letter to the drive?
You can probably get all the data from drive, using Ubuntu live CD, but you probably want to do it, without moving the data from the SSD.
Try minitool partition wizard, or aomei, and in those, partition recovery.
The best course of action would be to backup the files if you have space to do it.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
