Hi, so today I went on twitch to watch some streamers etc and my monitor said no signal, sound was still in background and stopped after a few seconds, my pc fans are normal so no overheat issue but on my vega 56 none LED was on, which means it has no power but how? I have 600w be quiet 9 power supply and was fine till now I also have everything up to date.
Full specs:
r5 2600 non overclocked
vega 56 with 64 bios
2x8 3000 mhz ram
B450M-A
https://linustechtips.com/topic/1157582-no-signal/
2 minutes ago, ShrimpBrime said:
Well it's a pretty low end PSU, I'd test that first.
Got a different PSU laying around?
no i dont have any different PSU, i tried putting -25% power limit and -50 core voltage in msi afterburner for my gpu and when i put it to default it automatically happened the monitor went no signal etc, so its 100% the psu? if so what is a good gpu for my specs?
https://linustechtips.com/topic/1157582-no-signal/#findComment-13312329
Quote
My guess was based off this comment.
Motherboard supplies power to the video card as well. If the PCI-E power cable was not plugged in, the LED color would change indicating no PCI-E power.
I suspect the motherboard does not respond or turn on also? If this is the case, I suspect the PSU to be bad.
If you have more information of the behavior of the PC, that would be helpful.
Does the Motherboard light up when PSU is on?
Does the PC post but without a picture?
Want to ask these questions to better diagnose the issue.
https://linustechtips.com/topic/1157582-no-signal/#findComment-13312342
motherboard only has illuminating effect and its always on when it has power so yes
pc posts with picture but when the problem happens i have to turn off my pc and when turning the pc back on i have to turn off/on the monitor for it to work
https://linustechtips.com/topic/1157582-no-signal/#findComment-13312351
9 minutes ago, moisty_worm said:
also now i tried entering cs go with -25% power limit and -50 core voltage and still it "crashed" like before
So you are saying the display driver has crashed??
If you are using windows 10 you can reset the video card driver sub system by hitting these 4 keys.
Press the Win + Ctrl + Shift + B keys. All at the same time.
https://linustechtips.com/topic/1157582-no-signal/#findComment-13312372
by "crashed" i mean the problem where it says no signal and on gpu power LED doesn't lit up
https://linustechtips.com/topic/1157582-no-signal/#findComment-13312374
No I cannot discord at this time. Will be offline in 5 minutes.
I suggest first installing the stock bios onto the card. Then see if the problem persists. They card may have gone bad.
If you have any issues with the bios, go to TechPowerUpForums. The Exiled Airman will assist you.
https://linustechtips.com/topic/1157582-no-signal/#findComment-13312382
my card has dual bios, i just have to switch the flip for bios
https://linustechtips.com/topic/1157582-no-signal/#findComment-13312384
