Hi guys!
My interesting issue with choosing the greater CPU around 200$ with great motherboard, with potencial overlock.
Of course with not low integrated audio motherboard R1200 and above...
I was thinking about 9600kf or 3600x with Z _ X motherboard, already have 2060s.
That will be better to bild intel or amd with 2 of this processors based, with 2060super?
Guys Thanks in advance!
https://linustechtips.com/topic/1157100-medium-pc-build-issue/
Not sure what the issue is??
200$ budget for cpu, but 0$ budget for the board is hard to give advice here.
3600x + x570
9700k + z390
Something like that seems most sought after mid ranged gaming.
2060s dont SLI. I use mine for folding at home. Team 234770. Just fyi there.
https://linustechtips.com/topic/1157100-medium-pc-build-issue/#findComment-13308267
3600x + x570
9700k + z390
i do know about chipsets for intel and amd.
But that will be better of this 2?
maybe good choose for this or that motherboard with medium range budget RaM for specific CPu.
All tests what i saw before, showing not that big difference? but always using different type of motherboard with different Ram speed(cl`s) and ssd`s
If i would have money for 9700k(r7 r9 3700x-3800x) i wound`t buy 9600k(kf), i would buy any ROG Asus Z_X or Aorus Extrime Z_X and etc.
If you wanna choose any nice MB, you thinking about good stock cooling for m.2 and other, and power for your CPU, possibility to use possible overlocking.
And nice Audio, Of course higher than 8xx Realtel sh.....
So this is it.
https://linustechtips.com/topic/1157100-medium-pc-build-issue/#findComment-13308776
