Hi i have a intel I7 4790 NON K, RTX 2070 and 16 gb ram (not sure which one) and ive recently just upgraded my GPU from a gtx 1060 however every game that i play seem to have a lot less fps then what i used to have with my old GPU so ive gone through everything i can think of ive even reset my PC all together and re installed windows 10 with all the correct drivers and im still not getting the fps i used to on my 1060.
For example when i play on CSGO 4:3 stretched MOST video settings on LOW and Vsync off im am only getting an adverage of 100 FPS but when i had my 1060 in i was adveraging 280+
can anyone give any advice on this ? or any type of help?
https://linustechtips.com/topic/1156207-games-not-running-full-potential/
Do you have the video cables plugged into the gpu or the motherboard?
1 minute ago, Jeike said:
into my gpu
What does cpu and gpu usage look like? How about temperatures?
If those cpu temperatures are correct, it is friggen HOT
Remount and repaste your cpu cooler
Just now, Jeike said:
So you think it will be my CPU which is not performing how it should be
Well if it's that hot, it's definitely thermal throttling
i suppose the intel CPU cooler which came with it 3 years ago could do with a upgrade then have you any suggestions for me ?
I'd go with any cheaper tower cooler. GAMMAXX 400 is pretty cheap and well performing
It shouldnt be going over 70 degrees
okay thats better for me im not sure on what good temps are tbh
CPU never above like 75 on MAX load
GPU around 82-83 is fair, anything above that is worrysome
Thanks ill come back once ive got the new CPU cooler installed see if it makes the difference
It most definitely will lol
ive now installed myself a Cooler master hyper 212 and ive noticed more frames however they still are not up to what they used to be on my 1080 and my temps are now stable 20-30s .
My CPU definately needed new thermal paste and a new fan i recon lmfao.
Here is what my CPU and Fan looked like RIPPP
