Hello, I have a CM MK730 and the LED underneath the F1 key is only glowing in red (it's an rgb keyboard). It's out of warranty and it really irritates me.
I opened it yesterday for some further inspection, however everything seems ok. I measured the current going through each channel and it returned the exact same values for the non-working one and the working ones. Which I guess means the problem is in the LED itself, since there's current going through them?
If anyone can confirm my statement is true, what led will I need to replace the faulty one?
I know it's a SMD RGB LED, but that's about it, I have no idea what the exact number is. So if anyone knows I'll be thankful if you'd share that piece of information!
PS: There's a picture of the LEDs that I took yesterday. It's kind of bad, but I can make another one, if needed, when I get back home.
https://linustechtips.com/topic/1155415-cooler-master-mk730-led-problem/
You can't measure current without having an open circuit, how did you measure it? maybe you meant voltage?
Quote or Tag people so they know that you've replied.
