That's not a UEFI BIOS and will not support Fast Boot. Its already disabled.
Main Rig:-
Server:-
https://linustechtips.com/topic/1153440-help-bios/#findComment-13280393
It is enable at the 1st picture.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1153440-help-bios/#findComment-13280398
Where?
Main Rig:-
Server:-
https://linustechtips.com/topic/1153440-help-bios/#findComment-13280491
1 hour ago, Kidplayer_666 said:
But it doesn’t allow me to access the bios unless I do a reboot, which is not possible in the troubleshooting that I’m doing
Which is the normal procedure for a BIOS. I'm not familiar with (E)UFI, so perhaps that does allow users to poke around in it via the OS (and only a specific one) and you're not used to a non-EUFI, true BIOS setup thus expecting too much.
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
https://linustechtips.com/topic/1153440-help-bios/#findComment-13280497
Care to explain the problem because I assure you, that BIOS does not support UEFI Fast Boot at all.
Main Rig:-
Server:-
https://linustechtips.com/topic/1153440-help-bios/#findComment-13280566
