Looking for help with my macbook. Here's the rundown -
I had used bootcamp to partition my ssd so I could boot either MacOS or Windows. I've used it for a couple years just fine. Well I decided that I didn't need Windows anymore on it so using the bootcamp software I followed the instructions on removing the Windows partition. Thats when the partition failed and it's no where to be found. So my mac is showing that I have ~200 gigs of storage when I should have ~250. So after trying many many solutions found online all involving the disk utility and macs "first aid" and restoring from a backup and factory resetting... Macbook still shows 200 gigs. Does this mean the other partition is gone forever and corrupted?
Main Question- How in the fetch do I do a full on wipe of my Macbooks SSD. EVERY SOLUTION I FOUND, only involves using the disk utility to do it. I want my SSD to be 100% wiped and start over. The disk utility and first aid don't do squat. However, I need the solution to include how to then manually reinstall MacOS or else it does me no good. Thanks in advance for anyone who has insight for this problem.
https://linustechtips.com/topic/1153252-hard-reset-macbook-pro/
First of all, I would recommend making a macOS install disk.
Next, you'd probably have to boot into a Linux USB and use GParted to completely wipe the Mac SSD, and then you can use your macOS install disk to reinstall macOS on the blank SSD.
https://linustechtips.com/topic/1153252-hard-reset-macbook-pro/#findComment-13278975
Okay i'm working on the macOS install disk right now.
One thing I didn't mention is that after trying a bunch of different things, I can't get my mac to do anything now. I was attempting an OS reinstall and for whatever reason my macbook won't make it past the install. i keep getting a screen that has a circle with a slash through it. Am I able to still somehow boot to a linux OS? Or is there another way that I can go about wiping the drive?
https://linustechtips.com/topic/1153252-hard-reset-macbook-pro/#findComment-13279056
what macbook pro is it? a circle with a slash means that you tried to install a version of macOS that the macbook does not support.
so the version you used is either too new or too old to run on your macbook pro.
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/1153252-hard-reset-macbook-pro/#findComment-13279269
GParted live - > https://gparted.org/livecd.php
When you mac starts up, as soon as you hear the chime, hold down the option key. This will give you the boot list.
Boot into GParted live, or a linux distro of your choice and open a partition manager of your choice, then create a new GPT partition table on the mac drive and leave the rest unformatted
Do the same to boot your MacOS disk.
If you get a circle with a slash through it, when your mac starts up. Restart it, and as soon as you hear the chime, hold down command + v. This will boot it into verbose mode, you should see an error somewhere specifying what went wrong.
https://linustechtips.com/topic/1153252-hard-reset-macbook-pro/#findComment-13279427
