My specs
rtx 2070 super
i7-9700F
16gb or DDR4 ram
600 watt psu
144hz monitor
1Tb of storage
ive been trying to get this pc to run on full usage for a while i usually get 60-80 gpu and 70-90 cpu in basically all my games PUBG gets around 60-90 percent gpu and I get between 90-150 FPS on ultra 1080p I play all my games on 1080p games such as rainbow only get 60-70 percent usage with dips from 250-150 which is extremely low and every game I try has the same affect some worse than others and my temps are cpu-60 gpu-70-80
Things I’ve tried
DDU drivers then reinstall them
change nvidia control panel settings up even high performance
muse regular control panel and change to high performance and change the pci express
try turning all my graphics up to improve usage
games I’ve tried
csgo fps-170-250fps
insurgency sandstorm-60-110fps
rising storm 2 Vietnam 90-110fps
rainbow six siege-150-250fps
PUBG-90-150fps
post scriptum-60-90FPS
squad-60-90fps
Mordhau-90-110fps
i know some of the games I play are unoptimized but the ones that aren’t shouldn’t be getting gpu usage so low I don’t how to fix been trying to for the last month if someone could help it would be really appreciated
https://linustechtips.com/topic/1152798-how-do-i-fix-gpu-usage-low/
Detailed post, but left out one really important part - What's your CPU usage like?
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
