Minecraft server and Website using same domain
Solved by mtz_federico,
20 hours ago, Insprill. said:Ok i should've elaborated more. So the redirect is there because my site is hosted by Tebex and they don't offer A records, so the redirect is there so if someone types example.net it takes them to www.example.net. But if someone type example.net/store it shows whats in the pic below. But it is also there so people can connect to the server and the site with example.net and mc.example.net
you need to add another redirect in a folder called store so that it redirects to the store url (www.example.net/store)
