i have been upgrading a old dell optiplex 790 (not small form factor) into a gaming pc are there a corsair 450 watt psu that would fit in my optiplex 790
and would the corsair 450 watt psu work with a rx 580
Main Pc: CPU: ryzen 5 5600x  Motherboard: Msi b450 gaming plus max  RAM: 32gb corsair vengeance ddr4 3200mhz ram  GPU: Nvidia rtx 2070 SUPER 8gb Case:  cooler master td500   PSU: corsair 750watt bronze80+  Cooling: Kraken x53 aio Storagewdblack snd750,3tb wd blue hdd
2nd Pc: CPU: ryzen 5 3600 Motherboard: Gigabyte AB350M-Gaming 3  RAM: 16gb 3000mhz gskill Aegis  GPU: Nvidia gtx 1650super 4gb  Case: Cooler Master MasterBox MB311L ARGB Airflow PSU: corsair cx 550watt 80+ bronze Cooling: Vetroo V5 CPU Air Cooler Storage: adata su635 240gb ssd, seagate 750gb 7200rpm hdd
3rd pc CPU: i7 2600 Motherboard: asus H61M-E  RAM: 16 gb ddr3 1333mhz GPU: nvidia gtx 1060 3gb Case: thermaltake versa h18 PSU: evga 450watt 80+ bronze Cooling: Cooler Master I70C (Copper Core) Mini CPU Cooler Storage: crucial mx 500 500gb ssd, wd blue 1tb 7200rpm hdd
https://linustechtips.com/topic/1150009-power-supply-help/
The 790 appears to use a standard motherboard so an off-the-shelf power supply would be a good call for an upgrade. Don't look at any old power supply, consider units that are better than the Corsair VS since this is for a gaming PC.
Yes, any Corsair power supply is compatible with an RX 580
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1150009-power-supply-help/#findComment-13253207
