So i have changed the fans and thermal paste on my zotac gtx 1070 amp!, then booted the computer and msi afterburner said that idle temperature is somewhere around 45 degrees Celsius. Happily i went grocery shopping afterwards, and now i came back to some crazy numbers shown to me by afterburner which says that my temperature is around 90 degrees idle and the fan is at around 90% while having 0 mV voltage. I am sure that these values are all wrong but why on earth do i get them and how do i fix it?
https://linustechtips.com/topic/1141676-crazy-gpu-temperature-and-fan-values/
Does it still show these values after a pc restart?
More links in my profile! Builds: Project(Main Rig): Cosmos Sv2 -- 2nd PC: Old School AMD -- Project: HD4890 Revival,
↓↓↓↓↓↓↓↓ Specs Below ↓↓↓↓↓↓↓↓
Cosmos Sv2:
  • CPU: Intel Core i9 9900K @ 5.1ghz
  • Motherboard: Asus PRIME Z390-A
  • RAM: Corsair Vengeance RGB Pro 32 GB (4 x 8 GB) DDR4-3000
  • GPU: Asus GeForce RTX 2080 Ti 11 GB Turbo
  • Case: Modded Cosmos S (Cosmos Sv2)
  • Storage: Samsung 970 Evo 500 GB M.2-2280 NVME, WD Black SN750 2TB NVMe, 2x WD Red 2TB raid 1, 150GB Toshiba 2.5"
  • PSU: Corsair HX850
  • Display(s): Samsung LC32JG50QQNZA 32.0" 2560x1440 144 Hz, LG 29UM58-P 29.0" 2560x1080 75 Hz
  • Cooling: Custom Loop
  • Keyboard: Corsair K95 Platinum
  • Mouse: Corsair Dark Core
  • Sound: Oboard with Logitech something or other 5.1 speakers and HyperX Headset
  • OS: Win 10 Pro
  • PC Part Picker URL: https://ca.pcpartpicker.com/user/NotSoEpicMods/saved/LYysZL
Old School AMD:
  • CPU: AMD Phenom II x6 1090T
  • Motherboard: Asus Sabertooth 990FX rev1.0
  • RAM: 16GB Patriot Sector 5
  • GPU: XFX HD 7950
  • Case: Cougar MX330-G Glass Window
  • Storage: 2x HyperX 3K 120GB SSD
  • PSU: Corsair 650W
  • Display(s): Samsung 32"
  • Cooling: Hyper 212+
  • Keyboard: Logitech G110
  • Mouse: Logitech M100
  • Sound: HyperX Headset
  • OS: Win 7 Ultimate
How long did you monitor the gpu before you left it? and did you stress test it before this happened? It almost sounds like you got a bad mount for the cooler.
Cosmos Sv2:
  • OS: Win 10 Pro
Old School AMD:
  • GPU: XFX HD 7950
  • PSU: Corsair 650W
I actually just looked at it for like 5 seconds and then turned off the computer. I checked if the fans are secured in place and they are. Can a thermal paste be an issue? Could it not spread on the gpu's core as it should?
Oh i just remembered that i did stress test it for like 30 seconds, if i recall it correctly the temperature was around 76 degrees (which seems normal) and i was using Furmark
A bad cooler mount could certainly cause undesirable temps and it doesn't take much. On my main rig it took 3 remounts of my gpu block and it turns out it was caused by a tiny amount of glue in the way of a mount. Anyways you could always try reinstalling afterburner before you try a remount.
Cosmos Sv2:
  • OS: Win 10 Pro
Old School AMD:
  • GPU: XFX HD 7950
  • PSU: Corsair 650W
Hey! So after a whole day of work it turned out that the problem was the fact that the port to which fans were connecting to the gpu board was not connected fully enough and i just had to push the fans connector down the port really hard. After that the fans are working. So crazy!
