8 minutes ago, Oneofseven said:
I've never seen this before, I went to remove my AIO to upgrade to a Ryzen 5 3600.
With my AIO came out my CPU and it appears to be glued to the contact. It popped right out of the socket with the locking arm down.
What do I do??
If you can’t get it out you can try twisting it, or use dental floss (but first method should work alright).
Also inspects the pins of that cpu, hopefully you didn’t bend any
   @Whiro tag or quote will do the trick
Steam Deck OLED 512gb , all other pc’s are gone
                                          WHIRO
         THE FIRST OF DEATH AND DARKNESS
        He feast on the dead to inherit their power
https://linustechtips.com/topic/1141642-cpu-stuck-to-aio/#findComment-13185131
