ram xmp help
Go to solution Solved by Mister Woof,
First gen ryzen IMC is pretty weak.
4 sticks is harder to get at max frequency.
Could try reducing to 2933 see if that works
hello i bought another 2x4gb ripjaws 3200 kit totaling 16gb now in my pc of the same ram same specs. Using my old ram i can get 3200 mhz no problem using xmp. but now when i put in the kit i bought it never boots into windows, sometimes blue screens sometimes boots into windows repair, when i turn on xmp. my cpu is a ryzen 1600 and asrock b350 pro 4. can i even achieve 3200mhz at all if up the voltage or is it impossible? motherboard limitation? i have no idea please help
https://linustechtips.com/topic/1138728-ram-xmp-help/
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1138728-ram-xmp-help/#findComment-13162721
3 minutes ago, PCnoobhere123 said:
very unfortunate if thats the case. 2933 using the same timings?
give it a shot  see what happens. you can try tightening them up later
https://linustechtips.com/topic/1138728-ram-xmp-help/#findComment-13162739
