So I am posting here since Razer's support has been useless in solving this matter.
I have a Razer stealth Early 2019 with the MX150 gpu in it and a razer core x with a GTX 960 in it(Temporarily until my 2070 super gets in).  The Core works perfectly fine with my Laptop and runs games as it is expected to, however, when I disconnect from the core and try to game using the MX150 I have to reinstall the driver for it before it will work again.  In device manager it shows this MX150 being disabled code 43 before i reinstall the drivers.  I would like to not have to reinstall the drivers every time I use the core at home, has anyone else had this issue and solved it? thank you in advanced.
All drivers are up to date on the computer, Razer acted like the problem didn't exist until I went through like a 15 step process to update drivers for literally every single device and program on the machine including the RGB controls.
https://linustechtips.com/topic/1137592-problems-with-razer-core-x/
