CPU not maxing out !!
Go to solution Solved by unclewebb,
The 34 multiplier is only used when a single core is active. The C states have to be enabled as well to use the highest multiplier.
http://www.cpu-world.com/CPUs/Core_i5/Intel-Core i5-2400 CM8062300834106.html
Some Intel CPUs support limited overclocking so you might be able to add +4 to those multiplier numbers. Try using Intel XTU or ThrottleStop or your bios to see what is possible.
So my i5-2400 has a base clock at 3.1 Ghz and a Turbo of 3.4 Ghz.
But under load my processor does not exceed 3.3 Ghz , Hence not turbo boosting to max (3.4 Ghz)
I know 100 mhz on 4 cores wont make much difference but i still want that.
I 've seen many users getting 3.4 Ghz while gaming and also if you go to userbench test there are many users who are getting full speed.
CPU temps are quite low.
It is 32 at idle and 55 at load.
Is there any settings to disable at BIOS?
Like CPU C STATES?
https://linustechtips.com/topic/1137431-cpu-not-maxing-out/
https://linustechtips.com/topic/1137431-cpu-not-maxing-out/#findComment-13154321
