GPU cooling upgrade
Solved by AndrewB121,
First you should try simply repasting the card or improving case airflow with some fans.
If that doesn't work there are basically 4 options:
- Arctic accelero coolers. The cheapest and probably the best bang for your buck. Kind ugly though imo. Should fix your issues.
- Morpheus cooler. Massive cooler that will probably be overkill. You'll need two fans as well. Looks pretty cool though.
- NZXT Kraken G12. Again probably overkill, but about the same price as the morpheus, while looking better imo. You'll need a compatible AIO and some extra cables. Isn't as hard a mod as it looks in my experience, and makes a massive difference.
- Custom water loop. Definitely overkill but looks sick and some like the DIYness.
Biggest factor for you is probably space, since it's a prebuilt. If there's nowhere to mount a radiator I would recommend the accelero twin turbo III, it's basically the same size as a normal GPU.
