·       What is the latest on upgrading RAM kits? It seems like with AMD specifically it matters less and less that you need to get identical kits in order for everything to work in harmony.
o   For example, if I have 2 x 16 GB 3600 MHz of G. Skill with timings of CL18-22-22-42:
·       Which of the specs below should I be most concerned with matching with when upgrading
§  Similar die / mem modules
§  Similar manufacturer (i.e. G. Skill)
§  Similar timings
§  Similar capacity - (could I buy a 2 X 16 GB kit and it would potentially work? - that’s what I would really like to do)
§  Same true latency?
§  Etc, etc.
·       Any advice or information would be great because I cannot find that much useful information online. It seems like the majority of advice I've read is "buy the exact same SKU of memory or your computer will blow up", which I am not sure is entirely true based off the very few articles I've seen from more reliable technical sources.
o   PS: I currently have 3900 X, x570 Taichi, and this kit from G. Skill - Trident Z Royal DDR4-3600MHz CL18-22-22-42 1.35V 16GB (2x8GB) F4-3600C18D-16GTRS
https://linustechtips.com/topic/1136647-need-help-w-upgrading-ram/
Those two must be the same it will be better having the same capacity (GB) but no bsuch a big deal.
Same latency
Similar timings
As for all the rest you don't have to care at all.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
@Constantin@Sir0Tek Meaning if I do get 2 x 16 GB - I should just remove the 2 x 8 GB kit completely? So its sounds like if I match the CL and timings are roughly similar its good to go, right? Could CL be off at all like 16 v 18 or should I probably avoid that?
16gb is overkill for any modern gaming, if you aren't running VMs or hosting servers don't buy more, it won't gain you any performance.  8gb is only *just* too small for some games, thus the occasional mild performance impact.
As for ram check these out
New Egg
https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232880?Description=3600cl16&cm_re=3600cl16-_-20-232-880-_-Product
Amazon
https://www.amazon.com/G-Skill-Ripjaws-PC4-28800-CL16-19-19-39-F4-3600C16D-16GVKC/dp/B07X8DVDZZ/ref=sr_1_1?keywords=ripjaws+3600&qid=1576903385&s=electronics&sr=1-1
MicroCenter
https://www.microcenter.com/product/612970/gskill-ripjaws-v-16gb-2-x-8gb-ddr4-3600-pc4-28800-cl16-dual-channel-desktop-memory-kit-f4-3600c16d-16gvkc---black
They aren't technically "Ryzen 3000 Ready" or w/e bullshit marketing, but i've only heard of them not working with XMP on a very few select motherboards/Bios updates, that likely updating to newer bios would fix.  They've been used repeatedly by Ryzen 3000 owners without issue.
No it mmust be the same!
No, if youu have empty slots put them no worries
Must be the same!
