2 minutes ago, Warking45 said:
Would this drive be able to record video at 1440p at 60fps?
What bitrate? But the answer is almost certainly yes, if you're talking about game streaming or game recording. Basically any WD Red Pro has a sustained write speed of around 160 MB/s (faster for some of the larger models)
Even if you were to crank up the bitrate to 1080p Blu-Ray levels, you're looking at under 50 Mbps (about 6.25 MB/s) - let's double it for 4K UHD Blu-Ray bitrate at about 100 Mbps - and you're still only doing about 12.5 MB/s.
Basically, recording video that isn't Cinema Grade isn't going to make the WD Red Pro even break a sweat.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/1134523-wd-red-pro-question/#findComment-13129607
