3 minutes ago, Founders said:
Is there anything already on the 2TB partition? When you initialized the drive why didn't you just initialize it at the full size if you didn't need it partitioned?
nothings on it. they were both unallocated when i turned pc on
1 minute ago, Mira Yurizaki said:
If there's nothing on the 2TB partition, you can delete it, then make a new one in the empty space.
both are unallocated now. when i right click the 5 tb part, everything is greyed out it wont let me make a new volume. it will only let me make volume on the 2tb part
