Hello
I have one question I want to build dual system pc and I use for build I use PSU
Lepa MaxBron 1000W 80PLUS Bronze
PRIMARY BUILD
- Asus tuf gaming x570-plus (Wi-fi)
- Radeon r9 390x
- Kingston 16 gb DDR4
- Ryzen 7 3700X
SECONDARY BUILD
- Asrock am1b-itx
- Corsair dominator 16 gb
- AMD Asus HD 7870 2gb
- CPU AM1 5350
I want to use this adapter for powering my motherboards
Will it work???
https://linustechtips.com/topic/1130919-dual-system-build-hellllp-please/
Hello @schranzwar and Welcome to the LTT Forum.
In theory it should work, but make sure your PSU has 2 CPU 8P conectors. And the correct number of PCI-E Conectors.
Recently in a minecraft server video, Linus used a splitter.
"Once there was an explosion, a bang that gave birth to time and space. Once there was an explosion, a bang that set a planet spinning in that space. Once there was an explosion, a bang that gave rise to life as we know it... And then came the next explosion. An explosion that will be our last"
"... To see the world in a grain of sand. Heaven in a wild flower
Hold infinite in the palm of your hand.  And eternity in an hour ..."
PC: 1
CPU: AMD Ryzen 9 3900X 4.3GHz 1.3875v Motherboard: AsRock X470 Taichi (BIOS: Agesa 1.0.0.3 ABB) RAM: 4x8GB(32) 3200MHzCL16 Hyper X GPU: GTX 980 Ti Waterforce Xtreme Core Clock: 1595MHz Memory Clock: 8000MHz Storage: SAMSUNG EVO 860 2TB(OS) / SAMSUNG EVO 860 1TB(Backup) Cooler: NZXT Hydro X72 360mm Case: NZXT Phantom 820 PSU: Corsair TX-750w Display Monitor: Monitor AOC AG251FG 240Hz G-Sync 1080p Headset: Headset LogiTech G633 OS: Windows 10 Pro 64-bit (Version: 1909 / OS Build: )
NOTEBOOK:
Model: Acer Aspire 5516 CPU: AMD TF-20 1.6GHz(1C/1T) GPU: ATI Radeon X1200(256MB) RAM: 4GB(2x2GB) 666MHz HD: SSD Sandisk PLUS 240GB OS: Windows 7 Ultimate SP1 x64
Good Question i think you could have Problems when Powering off one System:
When one of the Systems turn of i think that the Power Supply gets a Signal to turn off and maybe the PSU will shut down the second system to when the Signal was sended.
But thats only a guess.
1 minute ago, schranzwar said:
Yes it have my psu have 4 ....8 pin connectors two for main graphic card and 2 for secondary graphic card
Ok, but does it have 2 CPU conectors?
PC: 1
NOTEBOOK:
I uderstand but I want to turn off both of and turn off both at the same time I make Y splitter for
Recently in a minecraft server video, Linus used a splitter like this one:
Phanteks Power Combo Device for 2 PSU combine to 1 M/B with Power Redundant Function, Black Housing, PH-PWCOB_2P1M
This is 2 PSU and 1 system
I need 2 Systems and 1 PSU
I need this but phanteks does not sell this anymore
Negative, it's PSU Splitter.
PC: 1
NOTEBOOK:
Take a good look for my picture and your picture and tell me.
Hang on, i think i copied the wrong link.
Sorry about that.
PC: 1
NOTEBOOK:
