I'm having multiple issues. See pic. Also screen will flash black when opening anything. Complete system freezes often. I have no overclocks in use. All bios are up to date. Clean windows install. I am using two monitors and often with get no signal sent to main monitor upon boot. All temps are fine.
Specs
I5 8600k
Asus Prime Z390-A
Gigabyte 1080 to Gaming OC
EVGA Supernova 750 G2 psu
https://linustechtips.com/topic/1128632-is-my-gpu-going-out/
would you have another friend's GPU to test the system with to be sure if it's the GPU?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1128632-is-my-gpu-going-out/#findComment-13084744
Both have the issue?
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1128632-is-my-gpu-going-out/#findComment-13084755
2 minutes ago, Dalex81518 said:
Unfortunately no
I wouldn't say that it's definitively the GPU until you have something to test it against. Is this GPU covered by warranty?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1128632-is-my-gpu-going-out/#findComment-13084767
Just now, Dalex81518 said:
Yes
Did you try the Igpu (from the mobo)?
Does it do the same?
https://linustechtips.com/topic/1128632-is-my-gpu-going-out/#findComment-13084768
No it's too old
Since your CPU has integrated graphics, that's what you should test with then. If the issues are still happening, it might not be the GPU.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1128632-is-my-gpu-going-out/#findComment-13084774
