Ryzen build for work.
Go to solution Solved by FuzzyLogic,
I would just get a single 256GB M.2 drive, since the speed benefits offered by Raid 0 don't have as much of a noticeable impact when used with SSDs that are already very fast. The RAM looks good, but are you sure you need 32GB? You'd be able to reduce costs a bit if you decide to go with 16GB instead.
So, upgrading my current build as i need to run VM's and things like GNS3 and EVE-NG
Current
i5-4690K
8GB RAM
some super low end motherboard.
GTX 1060 6GB
Samsung 850 EVo
3 x Hard Drives.
650 WATT Corsair PSU (im sure its 650, i cant see it in my case atm)
to
Ryzen 3700X        https://www.overclockers.co.uk/amd-ryzen-7-3700x-eight-core-4.4ghz-socket-am4-processor-retail-cp-3b7-am.html
Corsair Vengeance 32GB (2x16GB) 3000mhz RAM             https://www.overclockers.co.uk/corsair-vengeance-lpx-32gb-2x16gb-ddr4-pc4-24000c15-3000mhz-dual-channel-kit-black-cmk32gx4m2b3-my-459-cs.html
MSI X570-A PRO (AMD AM4) DDR4 X570 Chipset             https://www.overclockers.co.uk/msi-x570-a-pro-amd-am4-ddr4-x570-chipset-motherboard-mb-34j-ms.html
My budget was around £600, this come in at £557 so still have a little money to play with. I can get 2x 128GB m.2 drives. Motherboard
spec says it can support 2 so is this worth it and running them in RAID 0? or just a single 256GB? Or should i get better RAM or motherboard?
Thanks.
https://linustechtips.com/topic/1128232-ryzen-build-for-work/
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/1128232-ryzen-build-for-work/#findComment-13081987
Yea ill get the 1 M.2. The RAM is for running various VM's and EVE-NG / GNS3 both are network simulators that eat up RAM for when im studying.
https://linustechtips.com/topic/1128232-ryzen-build-for-work/#findComment-13082005
I'd go with this ram instead, similar to yours in price and model, but 3600 speed which is more ideal assuming you aren't buying Samsung B-Die modules and tweaking the timings manually.
https://www.overclockers.co.uk/patriot-viper-steel-16gb-2x8gb-ddr4-pc4-28800c17-3600mhz-dual-channel-kit-pvs416g360c7k-my-104-pa.html
If you are absolutely sure you need the 32gb, you could get 4 sticks for 135£
https://linustechtips.com/topic/1128232-ryzen-build-for-work/#findComment-13082060
https://www.overclockers.co.uk/corsair-vengeance-lpx-black-16gb-28gb-3600-mhz-amd-ryzen-tuned-ddr4-memory-kit-my-4bw-cs.html
Need a 32GB kit, Thanks tho.
https://linustechtips.com/topic/1128232-ryzen-build-for-work/#findComment-13082069
